are the xy rear handbrake cables longer then the xw! think i may have the wrong one if so, seems miles to short. cheers
quickstitch,
Feb 14, 7:57pm
should be the same, the floor pan is the same, handbrake is in the same position. you may have a ute/panelvan or station wagon set-up, slightly longer
phil_10,
Feb 14, 8:01pm
its a sedan, have modified for fitting in a toploader so this may be my problem
livewire,
Apr 19, 3:57am
Xw handbrake cables fit to gear box crossmember, and Xy handbrake cables are different look at an XA cable they will be similar
