Mondeo handbrake
chuckyme, Mar 14, 2:00pm
how do you tighten handbrake on 95 ford mondeo
intrade, Mar 14, 3:48pm
maybe under car there myght be a plastic wheel to tighten like they did on early 90s modelyou need to crawl right under . I used to ajust em on car hoist
intrade, Mar 14, 3:56pm
http://www.at-online24.de/images/product_images/popup_images/5622.jpg
looks like this white plastic wheel are adjusters .
or it be on handbrake leaver pull up and shinea torch at to where the handbrake cable goes to the lever, inside car
plastic wheel from pix are under car to adjust.
chuckyme, Mar 14, 4:43pm
coulden see any way of tighting under car had o take off heat sheids jus has one cable in to t bracket then two going out of bracket no adjustment any were i can see
intrade, Jul 17, 11:57pm
probably insidecar then on actual leverpull it up and inspect where the handbrake cable is attached to the lever inside car.
