Its like those scenes with the fonz, speedo quits, I bang on the dash and "ayyyyyyyyyy" its working again. But its taking more hits than a nz cricket supporter to keep it working. its a 1998 d22. Electric not cable, odo still runs fine. I can take it out but where do I start looking!
msigg,
Jan 4, 6:33pm
Yea takeit out and send it to a speedo repairer it has a cold soldered joint. easy fix for the right person.
sandypheet,
Jan 4, 6:47pm
The older Navara I had the needle had bent (I guess with heat not speed)and was rubbing on the face of the speedo.Pulled it out and straightened the needle.
pettal,
Jan 4, 7:15pm
As above bentneedle , been there done that .
modie61,
Jan 5, 5:33am
as above x3
r15,
Jan 5, 6:03am
Nissan and their cheap nasty needles.
steelman3,
Jan 5, 6:24am
took mine to speedo repairers $90.00 and it was all done same as yours.
peacebird15,
Jan 5, 7:50am
Thanks guys, aayyyyyyyyyyyyyyy! (done with two thumbs up)
Aug 11, 11:48pm
Make that x4 Or 400. BUT the reason they bend is the rubbish material they are made of IMO. so be VERY carefull straightening it if it is bent.
