Holden 6 red motor
mansonprincess, Jan 4, 8:24pm
Ive got a 173 in my EH wagon, thinking about getting a new carb / manifold for her. IDEAS ! would a 450 4 barrel holley work! been told 350 2 barrel is not the best. Already have extractors, looking for a yella terra head also but not so easy to find anymore.
mrfxit, Jan 4, 8:50pm
Sorry can't help on that much but .
If it needs a rebore, they go easily out to std 186ci
Have you got freeflows or extractors (do you know the difference!) just checking ;-)
Triple stromburgs or SU's would be better all round
jenny188, Jan 4, 8:56pm
4 barrel and six cylinders, not a good balance. Triple carbs off xu1, but once again getting rare.
bamz1, Jan 4, 9:05pm
2 barrel holley
mansonprincess, Jan 4, 9:10pm
Yip Ive got extractors. I have been looking at the tripple carb set up and the twin / side draft . Im a car painter not mechanic so want to make it as user friendly as possible.
mansonprincess, Jan 4, 9:13pm
2 barrel holley. What size! would you use standard manifold with an adaptor plate!
mansonprincess, Jan 4, 9:36pm
i wish JMMA be cheaper to put a v8 in her
jmma, Jan 4, 9:42pm
He does say he may split, there is a cell number in the question, wouldn't hurt to ask (o:
mansonprincess, Jan 4, 9:55pm
Cheers JMMA will give it ago but im guessin its going to be too expensive
gmphil, Jan 4, 9:57pm
EH nice wagons not many those nw im guesn
mansonprincess, Jan 4, 10:01pm
HAHA what a waste of an EH. some people should stick to escorts.
mansonprincess, Jan 4, 10:07pm
no unfortunately they are a dying breed GMPHIL. I noticed you got a few parts 4 sale. You dont have a bonnet scoop for a VN ss do you!
mansonprincess, Jan 4, 10:11pm
I love the look of the tripples but might be a bit to complicated for me.
sr2, Jan 4, 10:27pm
I spent quite a bit of time modifying Red motors when I was reconditioning motors in Aussie in the late 70??
pico42, Jan 4, 10:32pm
Apparently the WW stromberg carb from the 253 engine is well suited to the red 6, according to www.oldholden.com
lookoutas, Jan 5, 6:57am
I learnt way back that the best way to hot up a car was to slot in the latest model engine possible.
i.e, I had all the go-fast on my Mk1 Z engine, but when it chucked one out-of-bed, I saved up for a Mk3 motor & box. That made it a genuine ton-up + car.
When first put in it had a Webber. Then I brought triple Stombergs which looked cool, worked well at revs, but were terrible down low and diabolical for hill starts.
I finally conceded and replaced the Webber, which dropped 5/8 of FA off the top end, but as sr2 sez - drivability was much better.
mrfxit, Jan 5, 8:43am
Gotta agree with the webber (mk4 Cortina)
Not meaning to pick on the OP but a lot of ppl still get confused between basic headers/freeflows & extractors (tuned)
loudnproud, Jan 5, 9:02am
wernt starfire rods standard in blue/black motors
attitudedesignz, Jan 5, 9:04am
Personnal experience says either double or triple carb's.
The problem with using single carb' on even a slightly modified 173 / 202 is the inlet manifold. They all (even aftermarket ones) have a funny angle on them ie, the rear inlet is higher than the front & middle inlet which causes # 6 cylinder to run lean, and over time the piston will sh1t itself. The piston top breaks off at the top ring groove, you here a faint knocking and the only way you'll know what it is is when it (top of piston) finally disintergrates or you take head off to find the knock. You'll see # 6 looks ok but it may be in a funny position compared to the others, so you touch it and it slides back down the bore & you think WTF, why did that move lol.
So either get decent after market pistons or go with double / triple carb' set up.
Oddly enough 161 / 186 never had this problem. 173 / 202 are the weakest of the reds. If you can find one get a 179 OR better still find a red motor with HP cast on block where it normally has 161-173-179-202.
My 2 cents coming from 30 years of owning & playing with Holdens (103 of them LOL)
attitudedesignz, Jan 5, 9:05am
Some but not all blue motors, 99% sure but could be wrong.
gmphil, Jan 5, 12:45pm
Had many models over the years always liked eh same bout the red one in the link .
yup believe i do check my last listn email in il dig out
gmphil, Jan 5, 12:48pm
+1 on that info
brokebloke1, Jan 5, 2:11pm
years ago I had a 1958 FC holden with a 186 red 4speed in her
carb I used was a XE falcon weber, make a custom plate to mount to std single barrel Holden intake manifold, bolt carb on run a 12v wire from coil for coldstart and make cable accerelater and away you go.
This gave power, and was cheap to run
mansonprincess, Jan 5, 9:19pm
thanks everyone for your comments - have had a few people over to have a look and have got some ideas, at the moment the two barrel holley looks like the go but im still open to ideas :)
ladatrouble, Jan 5, 9:36pm
Twin carbs on a 3 port head gives the best cyl balance - smoother running and easy to set up with moderate power increase. Might be hard to find an X2 manifold these days though.
