Have tried everything and cant seem to find it :/ Car stereo was recently stolen so wondering if the acc wire has been ripped out, does anyone know how to replace this wire! Cheers
reaperssoul,
Feb 22, 3:07pm
yeah sure run one straight from ignition,you need a tester,probe the back of ignition switch check which has power when key is turned on,then run a wire from thier careful not to probe any air bag wires if car has any and if you are not entirely sure just use the battery wire you already have at the stereo,use the acc and battery together,but that means turning your stereo off completey before leaving car,other wise it will flat battery
3962,
Feb 22, 3:08pm
I wonder what car specs are.*goes to look at crystal ball
leighfrancesca,
May 16, 3:57am
You could probably jumper the acc wire off a cigarette ligher socket if there is one nearby.
