Just had the wheel off my 1993 Nissan ute to find out why it was squeaking sometimes. Found that the inside brake pad has worn unevenly cause the warning tab to start scratching. The outside pad is normal and there is still plenty of wear left on it.
richard198,
Jan 7, 12:37pm
Seized piston. (outside)
candy1213,
Jan 7, 12:39pm
slides siezed, in caliper, or driving resting foot on the brake pedal a bit
hairchopper1,
Jan 7, 12:40pm
Can you explain a little more! There is only the one main piston on the inside of the brake shoe. Is that the only probable cause and if so how would I remedy it!
carmedic,
Jan 7, 12:56pm
+1
Edited to fix quote
richard198,
Jan 7, 1:01pm
If there is only one piston then the slider is seized as above. Dismantle and lube slide.
hairchopper1,
Jan 7, 1:09pm
sweet thanks
ceebee2,
Jan 7, 2:16pm
+ another 1
opuarobo,
Jan 7, 2:32pm
Is it you front or rear pads! If it's the front - I was wondering if you had noticed the car pulling to the side under heavy breaking.This would normally be an indicator of a faulty pad/caliper.
opuarobo,
Jan 7, 2:36pm
Forget my last comment. already diagnosed above.
Jan 7, 2:49pm
hairchoppper--once stripped cleaned up and lubed I'd strongly suggest making sure it now slides in and out smoothly. I recently had one vehicle with a slightly bent slide
techmen,
Jan 7, 9:15pm
do the slide pins on both front calipers,ensure rubber sleeves are intact,or get a couple of kits.I would flush the brake fluid through also.replace all the pads.check the rotor faces,especially the side that has wear,have seen this also from rotors that have a pad go to metal previously and not been machined.If you aren't confident to do this and get it 100% right,pay the money for a garage to do it.it's a wild ride in the wet when the' picks' are uneven!
the-lada-dude,
Jan 8, 7:35am
what are we talking about here karbanz
Jan 8, 7:48am
two "pins' for the non piston side to slide on.caliper must have taken a knock because one pin was bent about 1.5mm -just enough to cause binding -in fairness it was a ford courier -I checked everything else and still binding.one new pin later and all good as gold again
tonyrockyhorror,
Jan 8, 8:17am
*Woooooosh*
carmedic,
Jan 8, 9:14am
He's got stuff on his mind!
Aug 22, 2:56am
ok I'm running on zero sleep but still -Have I explained it badly!
