Put in a new msb isuzu box brand new.went to test and ouch stuck in first gear gearlever wont budge.Started engine isuzu elf and whiring noise like a stater noise and down on power even though batterys good.Put clutch in and wanted to move forward same with clutch out!any ideascheers
40wav,
Feb 25, 8:46pm
Sounds like clutch is not adjusted properly and is not disengaging. Have someone 'rock' the vehicle front to back while you try to get it back to neutral, then adjust or rebleed clutch. Other than that, dont know sorry, but thats where Id start. Good luck.
scoobeey,
Feb 25, 8:49pm
Ok cheers
suplyuparts,
Feb 25, 9:14pm
put the clutch bearing in the wrong way.!
scoobeey,
Feb 25, 9:21pm
No pretty sure right way :)
scoobeey,
Feb 25, 9:36pm
Gearlever stuck even when motor off.Selectors where fine on old box.
scoobeey,
May 27, 6:10am
I took the linkages off the box and jacked up the back wheel and shes free as a bird .top linkage on box moved but bott linkage not moving by hand !
