Any one worked on abs for a 1994 ford probe gt
reaperssoul, Feb 25, 5:12pm
codes come up with F/L and R/R abs sensor,replaced those,cleared codes and now same thing again,mind you the abs and air bag mil comes on at same time,any idea
serf407, Feb 25, 6:05pm
Have you looked on the US Ford Forums to see if anything is written there !
I can understand why someone would want to drive a car like that when I see the amount of cars with panel damage in South Auckland car parks. Dirt Trackers have less panel damage than some.
male_timaru, Feb 25, 6:55pm
didn't know that probes had good stomach muscles - let alone good anything else
reaperssoul, Feb 25, 7:11pm
i know the fords are a piece of sh#$ but its some one else car and i have to fix it,checked on the usa ford site not much good info thier
jasongroves, Feb 25, 7:18pm
What are the airbag trouble codes!
Once you have switched the ignition on, you have to wait 45 seconds for the airbag lamp to start flashing.
reaperssoul, Feb 25, 7:35pm
thier are no air bag codes,i put the car in to diagnostic and all i get are the abs codes,no codes for the air bag
when i erase everything it will go good for some time 10min or sometimes 5 and then bam the 2 mill come comes on(yes i have replaced those 2 sensors it picks up on)
one other thing the car does is that the pedal at low speeds makes electronic noise sometimes like abs doesnt know whether to enagege or not
franc123, Feb 25, 7:42pm
given that much of the body and chassis electrics and drivetrain are shared with the Mazda MX-6 there might be more information in forums associated with those.
ginga4lyfe, Feb 25, 9:32pm
you probably have a short in the wiring or the abs Control unit is faulty
un_known, Feb 25, 10:21pm
foxdonut, Feb 25, 11:31pm
Whatever happened to that guy that used to post here about the tens of thousands of dollars he planned to waste turning Probe into a "10 second show car"!
reaperssoul, Feb 26, 7:49am
i replaced the abs control unit,that didnt help,gues its time to strip the blimin wires on that crapper
reaperssoul, May 27, 1:17am
he's probably in the asylum now
