We have a water leak inside the car on the passenger side front which seems to be coming up from underneath the car. Problem is the car is stationary and we cant find out where its coming from. Inside car,windows etc and panels are bone dry yet the carpet this morning is soaking wet. Any one ever had this kinda problem and anyone got any ideas where it might be getting in! Car is parked on a slight slope.
howz_that,
Jan 13, 8:12am
does the car have roof racks or any other holes in the roof!
richard198,
Jan 13, 8:14am
Most common is through area below windscreen corner, inside guard, down through kick panel area. Unlikely that water will travel up. Pull the left side kick panel and look for water behind there.
kwdriver,
Jan 13, 8:15am
I have had the same thing and thought it was coming from underside of car, but it turned out to be the front screen. The water was running down behind the dash onto the floor and couldnt be seen when hunting for the leak. I would be inclined to get it resealed and work from there.
herbiem,
Jan 13, 8:22am
Thanks for that everyone. Had water leaks before this one in other cars but this 1 ahs us stumped . We realise water cant run upwards but everything inside car apart from carpet in that 1 area is completely dry. I,m thankful Its raining at moment [we need it] but I dont need this.
robbo36,
Jan 13, 8:24am
If no leak found from the windscreen, then it could be a leak from the heater core or hoses! Check up under the dash behind the glovebox. What make / model of car do you have!
herbiem,
Jan 13, 8:27am
81 Mitzy Sigma
un_known,
Jan 13, 8:28am
yep id say its the heater core. checked the level of your radiator recently
budgel,
Jan 13, 8:28am
My son's car had that problem, it turned out to be water getting between the glass and rubber on the passenger's door and coming out behind the door card. the bottom of the door had over a litre of water in it! Opening up the drain holes in the door was the answer for us.
herbiem,
Jan 13, 8:34am
All drain holes r clean and radiator is all good. Looks like we go check windowscreen 1st. Thank everyone.
Jan 13, 9:28am
Most common would be rubber on windscreen lets water inside you wont easy see it you would have to shove down some napkins and use a hose on windscreen to see ifnapkins get wet below the dashboard. Rust is a other big possiblity on one of these.
ninja_man,
Jan 13, 9:32am
i also have the same problem, it seems to be coming from the windscreen. is it possible to fix myself or get someone to do it
Jan 13, 10:18am
What car year and can you tell if it is glued in or rubber seal! if you cant tell then you need a professinal. to do it for you
ninja_man,
Jan 13, 10:41am
1997 integra type r. Not sure if it is rubber seal or not
81 sigma is higly likely just a rubber on windscreen . the ninjaman one will be glued in= no removal without braking DIY rubber screen like 81 sigma bush out with plastic tool like screwdriver and pull back in with rope. diy possibile with small know-how
