hey hi have a 2l honda aspire 5 cyl 1992no1 hasmint spark .num 2 weak and 3, 4 and 5 have none! why would this be!dodgy dizzy! cracked head ! or typical crappy honda hahah
jasongroves,
Jun 15, 4:06am
Auto sparky would be able to diagnose pretty quick;) Have you used a multi-meter to test for voltage from the coil to the distributor and from the distributor to each lead! Also need to check impedance of the HT leads. Take the dizzy cap off and check for corrosion or worn contacts.
