Hi there, Uncle as you know I have a W111 220SEb 4 door Mercedes benz Fintail. I have an in top order KM/H speedo head that I was given from a European one and I'm wanting to know if it swaps directly in place of the present MPH one! The only gearing difference I suspect would be for the odometer in the head itself .am I right in thinking this please!
gammelvind,
Jan 14, 5:41pm
From my memory when I had my wrecking business in these lovely old girls, it should drop straight in.
andrewph,
Jan 14, 5:46pm
Yes it should fit straight in. Be very careful of the capilary line for the temperature sender when fitting as they are getting harder to get.
ema1,
Sep 17, 7:56pm
You're dead right about the capillary tube, I have several spare temp gauge units here still charged and operational. I thought it could be a straight swap and most likely the only difference between the KM/H and MPH units is the gearing in the head for the odometer & trip meter , both being driven from same gearing. Thanks guys. BTW the MPH head is 120MPH and the KM/H one is 200KM/H so same ratio in the read out of the speed at least.
