So. I'm attempting the change the brake pads on my 1991 SV30 Camry. Something I haven't done before. Got pads out, 'someone' stood on brakes and the round (piston!) type thing in middle has come out and won't go back in! How do I fix this! Can't put pads in with it like this. Cheers
jasongroves,
Mar 3, 10:41am
Take the lid off master cylinder. Slide one of the old pads in so its sitting against the piston. Get a 'C' clamp or similar and use it to lock the old pad against the piston.slowly tighten the 'C' clamp until it pushes the piston back in. Keep an eye on fluid level as you do it so it doesn't overflow.
Who pushed the brake pedal! You might wana use the 4 muscles that cause your hand to slap em up side the head. Is it right out or out abit!
toxicgreen.,
Mar 3, 12:30pm
People got it wrong,, You have to rotate piston clocwize to send it bac in,,its envolved in handbrake self ajuster so rotate it bac in.
jono2912,
Mar 3, 1:16pm
Hey guys, got it back enough with Jason's advice, and now the pads are actually in I don't have enough clearance to get the pads back over the disc! Is this before I haven't got it back enough!
jasongroves,
Mar 3, 1:21pm
Yes, in some cases, on some makes.on the rear brakes.
jasongroves,
Mar 3, 1:22pm
I would say so.
jasongroves,
Mar 3, 1:23pm
And make sure the pads are seated correctly;)
jono2912,
Mar 3, 1:23pm
Psh, I don't wanna take them back outtt.
lol
robertsons-nes,
Mar 3, 1:24pm
didnt realise the handbrake operated off the front brakes as well. also did you make sure the pads actual back plates were 100% identical before putting the new ones in i know on some mazdas they look the same but are about 10 mm differant but yes if they are the same you need to push the piston in further
jono2912,
Mar 3, 1:26pm
They looked the same, didn't measure at all, but BNT are usually pretty good with that anyway.
jono2912,
Mar 3, 1:26pm
Cheers guys back soon.
jono2912,
Mar 3, 2:19pm
Okay, so one side all done. On other side now, but master cylinder is full, and it won't go down!
xs1100,
Mar 3, 2:40pm
loosen the bleed screw now and then replace pads and then bleed whole system starting at furtherest brake bleed nipple from master cylinder 1st
jasongroves,
Mar 3, 2:50pm
Or just remove some fluid from the cylinder and top up when done. You don't need to bleed the brakes.
jono2912,
Mar 3, 4:11pm
Yeah Jason, ended up doing your method.
Cheers for your help. All done.
xs1100,
Mar 3, 4:27pm
why not probably havent been done for ages and the fluid is hydroscopic (absorbs water) which will then boil when it gets hot enough causing brake fade just top explain complete story
johnf_456,
Mar 3, 4:31pm
Nothing wrong with bleeding the brakes at the same time, brake fluid should be changed just like oil. Not at the same interval of course, but its needs to be changed so doing it while doing the brakes makes sense.
sr2,
Mar 3, 4:42pm
I think the word you were lookin for was "hygroscopic", good advice however on the regular fluid changes.
johnf_456,
Mar 3, 4:48pm
I think the word you were looking for was "looking" not "lookin".
wills,
Mar 3, 5:10pm
I think the comma you were looking for, should have been placed after the second use of the word "looking".
keith18,
Mar 3, 6:31pm
dont forget to put your foot on the brakes a few times before driving off .this adjusts the pad to the right position
3tomany,
Mar 3, 6:37pm
theres no fun in that
