Help with Holden
mitchell_nz2005, Jan 17, 9:10pm
hey ive noticed that automatic transmisson fluid must be geting into my radiator is there anywau to stop this . And if it is getting into the radiator will it be getting into the transmission thanks
matarautrader, Jan 17, 9:19pm
Is it an EH Holden with genuine slip -o - matic, or barina or what!
mitchell_nz2005, Jan 17, 9:23pm
sorry it a 98 holden commodore accliam vt v6
ralphdog1, Jan 17, 9:30pm
Yes and probably.
For starters replace the Radiator, ad at the least you will be up for a complete trans flush
mitchell_nz2005, Jan 17, 9:43pm
Ok so ill just need to replace the radiator so dont need to replace automatic transmission
treachug, Jan 18, 5:14am
May still need a transmission - depends on how long the water has been leaking in there & what damage it has done.
alan1111, Jan 18, 5:25am
Buy a trans oil cooler cheaper than a new radiator.
brokebloke1, Jan 18, 2:41pm
better for the transmission too as they run better when they are cooler
unbeatabull, Jan 18, 4:31pm
I assume these have a trans cooler built into the radiator!
You will need a new radiator, new trans fluid, gasket and trans flush and coolant at the very least If you are lucky.
Trans don't like coolant at all . it might be ok short term but you may need to strip down and overhaul in the future
scotty20001, Jan 18, 4:38pm
all VX Holdens have trans coolers built in to the radiator, as said new radiator and trans flush should sort it out.
rocky0169, Jan 18, 6:55pm
Trans cooing pipes flow thru a header tank. if fluid is getting into the coolant then pipe may have split in it inside the header tank. replace radiator
yeahm8, Jan 18, 7:06pm
If fluid is getting into the coolent, then wouldn't one assume that coolent would also be getting into the fluid lines to the tranny!
rocky0169, Oct 2, 6:13am
. could allso be case too
