ABS Sensor 92 Corona?
dasfi, Mar 7, 7:15pm
Recentlythe front right wheel took a bit of a hit, now when driving and when you break sometimes the pedal feels like the abs is kicking in! is there a damaged sensor somewhere on the hub or wheel somewhere!
dent, Mar 7, 7:21pm
possibly damaged the sensor or the teeth on the c.v joint. Sounds like you shoud get it chked tho.
dasfi, Mar 7, 7:28pm
yea taking it for a wof this week and see what they say! could i ask where the sensor is and what the teeth on the cv would ave to do with it!
robbo36, Mar 7, 7:30pm
Don't think Coronas had ABS fitted that year. I have a 93 Corona, NZ New and it doesn't have ABS. Doesn't sound good whatever damage has occured, it needs to be checked out. Could be a bent front rotor. What did you hit, road island, curb!
dasfi, Mar 7, 7:32pm
concrete piller in f**kin wherehouse carpark
cocabowla, Mar 7, 7:34pm
mine had abs but it was the upspec glx
dasfi, Mar 7, 7:36pm
mines a EX Saloon, with the electric windows and seats
intrade, Mar 8, 6:28am
usually if abs is damaged then it wont kick inn no more.
you do realise you have to change brake fluid every 24 month or it will not only seeze your brake caliper it also roots your abs unitwith rusty water master-cilinder the lot.
dasfi, Jun 30, 6:11pm
ok will have to check those things and yes also has traction controll
