Help please suspected fuel pump not working
lmfao-, Mar 13, 10:07am
Just got given a 94 integra no gas is getting to the carbs.Just disconnected hose from fuel filter (attached to the tank) and petrol came out the hose would that be in there if the pump wasn't working or could it be just a blocked pipe!
dent, Mar 13, 1:07pm
if there is fuel comming out the pipe with the key on or cranking it wont be fuel pump. Check for spark.
jasongroves, Jul 16, 4:04am
Do you mean you disconnected hose from the pump! Or the filter!.which should be under the bonnet.
Have you checked condition of the filter!
Is there fuel in the sight glass/bowl!
