mate a carburetor has no fuelpump inside the tank. your fuelpump is mounted on the engine most likely on the head and is a mechanical membrane low pressure pump only injected have pumps inside a tank.
What a cool website, breaks down all the parts for Hondas
lmfao-,
Mar 13, 2:40pm
thank fuck you came along LOL
Mar 13, 2:51pm
well i an not 100% sure but reading it being a carburettor and him not finding a pump inside the tank . As i cant recall a car with electric pump and carb. the 1.5 civic i fixed had a mechanical pump on the engines cilinder head .
lmfao-,
Mar 13, 2:52pm
any clue as to what it looks like so I know what Im looking for!
above is what 90% of mechanical membrane fuelpumps look like.you might as well wirebrush your petrol tank and give it a coat of mat-black before you screw it back up and inspect inside the tank for dirt. and if the pickups are not broken off or coroded in the tank
dent,
Mar 13, 3:13pm
I cant say ive seen a honda of that age with a mechanical fuel pump even with carb versions. I thort they all had low pressure electric pumps.
Mar 13, 3:18pm
civic was 94 model membrane pump on head just like his. also you might confuse a single point injector with a carburetor as they look like acarb from outside.! http://www.angloparts.com/en/catalogue/picture/2353
Mar 13, 9:51pm
he foundit in post 16 rocky728
illusion_,
Mar 14, 7:14am
Thats certainly a fuel pump . but it looks like it has been disconnected/unused for some time. One wonders what has been pumping the fuel since then
Jul 16, 2:17pm
its why i asked if it was his engineits probably poked. he will have to go along the fuel lines to see if it got blocks etc and also blow the lines clean with compressed air before refitting thepainted fuel-tank.
