Koni front suspension question
rotormotor7, Jun 7, 11:56am
ok have a full set of old school koni adjustable dampening suspension for RX7.
rears middle shaft pushes in and springs back out just fine of shaft body
fronts however push in with audible "air bubbles" escaping i imagine past the internal seals and they do not spring back out and remain largely where you leave them.
i would think they would behave like the rears and spring back out so suspect are stuffed.
anyone!
cheers
bill-robinson, Jun 7, 1:00pm
Phone George Stocks on 09 270 7218 and speak to them. Have the part numbers off the shocks when you call.
Bill
rotormotor7, Jun 7, 1:05pm
asked on a forum ~ oil fronts/gas rears hence discrepincies. front springs hold the shaft out and no leaks so 'should' be sweet to use.or can be rebuilt apparently.pretty old though.
looking to sell 'em hence the question.i dont sell busted stuff :)
cheers
saki, Jun 7, 1:20pm
They have been lying on there side and need to be held vetically and primed close and extend until no bubbles.
laneyjan, Jun 7, 1:48pm
some are single action and some are double action
clark20, May 18, 8:57pm
Stocks have a shock tester so you could sell them with a graph.
