Daewoo Nubira Distributor, where do you find it
rrtipene, Jun 1, 8:33pm
Hey guys in the know, does the daewoo nubira have a distributor.
All I can find is an ignition coil attached to the block.
Hey his is the first time I have seen such a thing.
Please advise
ginga4lyfe, Jun 1, 8:54pm
if they only have an ign coil on the block, and no obvious other dizzy's then it must be run from the ECU/ign module and timed from the Crank angle sensor or cam sensor,
rrtipene, Jun 1, 9:02pm
OK, the coil is not firing from one of the outlets, does that mean the coil will need replacing or will it be the crank angle sensor or cam sensor.
Car starts first pop, but missing. That is where I found that one coil outlet will not fire.
Your advice will be helpful
ginga4lyfe, Jun 1, 9:12pm
will more than likley be a HT lead or plugs causing the issue, at worst the coil pack may be faulty, but start with the easy and cheap things to test/replace
tadpole7, Jun 2, 7:46am
Gee motors in Napier are stockists of Daewoo parts.i am a Daewoo owner and have had very good service from them.
rrtipene, May 5, 1:07pm
Hey dude, I checked the lead and it was stuffed and then I started the car and removed each lead from the the coil and found no spark at one outlet on the coil. So I reckon it is the coil, $85.00 second hand in NZ or US$50 brand new imported. hows that for a a bargain
