Have a 95 lancer, 1500cc carb engine. Is running really rough, worse when cold, coughs and serges when excellerating. Today changed air filter which was dirty and fuel filter but hasnt really made a difference. Any suggestions! Thanks
phillip.weston,
May 31, 8:11pm
I would look at spark plugs, distributor rotor/cap and ignition leads.
selwyn_peters,
May 31, 8:14pm
Ok thanks will check that out tomorrow, Needs an oil change badly too but that wont effect rough running will it>
phillip.weston,
May 31, 8:19pm
probably not. But I would do an oil change anyway.
May 31, 8:59pm
check that the auto choke is working properly, IIRC on those they are a water heated waxstat type which is sensitive to either blockage of the hoses going to it or low water levels.If it gets stuck in one position it can cause all sorts of driveability problems.
selwyn_peters,
Jun 1, 9:32am
ok thanks will check that too
jrlaw,
Apr 27, 3:49am
Must get the temperture up to normal in a couple of k's, if not thermostat would have failed.
