i have a honda odyssey pretige how can i adjust the suspension to raise it as it has adjustable suspenssion
rotormotor7,
May 23, 3:51pm
jack up a corner,remove a wheel and you should see the threaded strut with 2 locknuts.
either get the right spanner or a screwdriver and hammer in the slots and break the seal between the 2 nuts ,CRC the threads as bound to be full of dirt and adjust to suit.
dent,
Mar 24, 10:16am
it should be certed for the current adjustable suspension. Therefor you can only change the hight listed on the cert plate by 5 percent
