any 1 know the size of them from factory need to buy a new set
hoarder635,
May 15, 12:43pm
most v8 vx commies use around a 310mm rotor which will prob run you around $250 each
hsv R8s generally use the largeer 330mm rotor that are over $1000 each
if this is the case its cheaper to get two piece rotors from 0800racebrakes they will run you about $700 each first time for rotor and center hat then only about $250 per rotor replacement after that
Depends on what type are fitted. The performance ones (Standard fitment on the R8 I think) 330mm x 32mm front 315mm x 18mm rear or Premium ones with 4 piston calipers 343mm x 32 and 315 x 18. Pretty sure the standard clubsport ran standard commodore brakes 296mm x28mm.look up DBA, RDA they all sell/make them.
