4d56 gearbox
cbrowniego, May 10, 8:23pm
i need a gearbox for a 4d56 generation 2.1992- 1998 pajero or delica l200 l300 most 2.5 mitsi diesels.manual ones are getting tricky too find :)
paul271, May 11, 6:42am
Ive got a 2.4 petrol one, from 01 triton. That any good!
phillip.weston, May 11, 8:24am
Pajero is floor shift while L300 is column shift, so the box casings are different, so I would say most of the internals such as gears and shafts would be the same, if that's what you are after specifically.
cbrowniego, May 12, 6:15am
thanks paul but dont think the petrol is compatable
skydog, May 12, 10:23am
is this a 4x4 box
elvis58, Feb 9, 8:08am
I know that the main gearbox internals on the mid to late 80's 4d56T powered pajero's were the same as the sigma station wagon box's of that era. I bought a 87 that had selected 2 gears at once and used these parts to fix mine. Same with the petrol powered L300's that used to do the front bearing and wreck the lot, so it may be that the internals swap on most models. Trouble now is those old rwd box's are no longer plentiful or cheap.
