Have a set of cheviot tridents,14x7" fronts and 14x8" backs to go on my VR commodore. . . only problem is my wheel studs are to short. . . where in christchurch could i get a set of longer studs!
thunderbolt,
May 3, 2:49pm
Repco or Appco deal with a company that supplies wheel studs and nuts, they should be able to get you something.
petermcg,
May 3, 3:04pm
VB - VL = 43+
VN = 43+
VP = 43 + optional offset is 42 + or 31 + for V8 Exec sedan VP Berlina = 26 + VP ABS IRS = 26 +
VY Exec V6 = 43 + VY SC V6 = 41 + VY Exec wagon = 43 + or 41 + for the 5.7 L VY2 = 43 + VY2 SC V6 = 41 +
VZ Exec = 43 + VZ Acclaim = 41 +
petermcg,
May 3, 3:05pm
I just Posted the offsets for those holdens, make sure that the PCD is correct as some of them are different
pnh4,
May 3, 3:14pm
Most Tyoyta 4WDs are long type try the wreckers or pick a part if you got one down that way.
demons,
May 3, 3:52pm
ummm get the right wheel nuts cant use vr ones.internal they are most likely non centering wheels
by_hdt,
May 3, 3:55pm
why would you downgrade to tridents!, #1 they look gay on anything post-1978, the stock hubbies would look better. #2 the factory wheel size is 15" even on the crappiest of VR's #3 the VR was designed to have 15" wheels at a minimum, so putting 14's on will stuff up the suspension geometry and wont clear the brake calipers on the front either, as VP onwards had the VL Turbo calipers and rotors, which required the fitment of 15" wheels, My guess is the studs are too short because the wheel wont go on fully because it will be hitting the brake calipers.
im_andrew,
May 3, 4:38pm
You cant fit a 14" wheel on the front of a VR, it wont clear the brake calipers. Also, if they are kingswood wheels they are the wrong stud pattern (5x120.5 i think), and it will load up the studs and stuff them
ali.m,
May 3, 7:23pm
What are yous on about. . . . . Ive got 14x8" modgies on it at the moment with no troubles!. . . and by_hdt do you really know anythin geometry! or just trying to sound smart! ha! and the wheels themselfs clear the break calipers and all just fine and my suspention set up is far from factory so ill be just fine. . . best no what your talking about before you speak next time huh, DEMONS was rite all i needed was shank nuts,cheers mate will be sitting pretty tomorrow :).
im_andrew,
May 3, 7:30pm
They dont fit mate, I have tried 14" VN steelies on the front of my old vr and they didnt clear the calipers
I've got five colourful pieces of paper in nice wooden frames hanging on my wall, plus during the hours between 8 and 5 I am tasked with working on very expensive motor cars you have probably never heard of, let alone sat in, with systems and sub systems so complex your feeble mind could not comprehend. So yes, I believe that more than qualifies me to speak.
ali.m,
May 4, 8:19am
Well there now on the car and all is fine. . . . , would you like a photo to prove it!. . . . i can show you one of the other 14x8s that were on it before too if you dont belive.
bubbles52,
May 4, 12:47pm
why why why would you put old school rims on a late model, would look just as gay as the AU XR6 with 12 slots, made me sick
xacoon,
May 4, 1:04pm
I usually prefer more rubber than rim, not a fan of rubberband tyres, but for the record arent they actually tridens! remember looking through an old catologue once that listed them as such. horrible rims, never understood them. each to their own though I suppose
roys351,
May 4, 3:27pm
tridens may have been a typo never seen or heard them called that
roys351,
May 4, 3:29pm
yea and your right xa coon i think anything bigger than a 15 looks crap on our cars
xacoon,
May 4, 3:32pm
figured it was just like the amount of people that call a familia a familiar, and the last t just stuck. was a couple of different cheviot brochures I seen it in, dunno, was a while back
xacoon,
Jan 12, 1:58am
yeh might have been a pamphle of theirs
