2002 mitsubishi magna air con/heater fan controler
tiny15,
May 17, 8:04pm
fan only works on the 2 highest speeds now, would it be the switch or the resistor? also where would the resistor be located ? TIA
May 18, 5:38am
I'd say it's the resistor and it is normally screwed to or near the fan box assembly under the dash.
Jan 26, 3:19am
Generally below or begin the glove box, normally just a rectangular plug with a number of wires going into it is all you can see.
