Anyone had experience with the Mercedes E320 104 twin cam motor leaking oil from the point where the head, block, upper and lower timing chain covers meet. I replaced the timing chain cover gaskets 6 months ago and the problem has re appeared. Apparently it is a known problem and the only long term solution is to replace the head gasket with the latest factory upgraded version. I??
johnf_456,
Apr 23, 1:37pm
Its a common fault I have done a few, its not to bad to do once you know what your doing. But then again I don't help apparently.
The gasket you used last time was this a genuine or an after market one!
jmma,
Apr 23, 5:00pm
johnf_456 wrote: Its a common fault I have done a few, its not to bad to do once you know what your doing. But then again I don't help apparently.
So nows your chance to help, are there any pointers you can suggest to make the job easier!
carmedic,
Apr 23, 5:01pm
as john would say. +1
jezz43,
Apr 23, 5:08pm
ive done loads of them, they are relatively easy, i used to work in a mercedes workshop. theres no real easy way to do it, but it can be done in about 2 hours with ease. use a piece of wire to hold the chain to the side when you remove the camshafts. check the head over when its out etc. just common knowledge stuff
johnf_456,
Apr 23, 5:09pm
I have anawered the question I have not just said plus one which does help by confirming what another person has said.
It is common and I have asked if the op used genuine or after market parts!
So I cant see why you guys think its not. As for the job its not hard not that much different from a normal head gasket job.
carmedic,
Apr 23, 5:46pm
Yes right you are nismo.
sr2,
Apr 23, 6:55pm
Thanks for the advice guys; it seems a shame to pull the lid off a motor that's in such a good condition but it looks like I'll have to do it, the oil leak is not too bad but it's enough to get on my wick! The timing cover gasket I used was sourced from Startech Enterprises in Manakau, they are a good company to deal with and I have a lot of faith in the quality of their parts, they make owning a 90??
jezz43,
Apr 23, 6:57pm
startech are fantastic. they used to supply all the parts i needed when i worked on mercs. if they didnt have it, they got it for me from mercedes in germany. bloody good service from those guys.
sr2,
Dec 5, 12:58am
Big thanks to monzaman who gave me a call with some gasket advice. There are a lot of helpfull well informed people on this MB.
