Water in LPG from supplier
epal, Apr 22, 11:34pm
This week, I have had a lot of trouble, keeping the motor running smoothly - keeps cutting out, when on LPG: petrol, no problems!
Would water in the LPG supply be a possibility!And, if so, would anyone have had any experience gaining compensation from the supplier!
ginga4lyfe, Apr 22, 11:37pm
have you drained the LPG canister int eh engine bay! they do accumulate with water and need to be drained once in a while
berg, Apr 23, 5:07am
Not much chance of water in the LPG (was in the LPG business for a few years). More likely to be wax build up in the converter or a vacum leak/diaphram problem somewhere.
intrade, Apr 23, 6:42am
your evaporater is heated by the engine coolant. you probably have that blocked or not enough coolant in the system . with no warming the evaporator will ice up after about 500 meter down the road.
epal, Nov 30, 5:56pm
Thankyou all - you have put my mind at ease. The tank is due next month, for it's check, so will have everything serviced then.
