Seems high! Is the $250 extra cost specifically for the overheating checks! Ask for a breakdown of the bill - all labour, use of pressure test equipment, diagnostic gear, distance of road test, any parts or antifreeze used etc.
rgflav,
Apr 19, 2:49pm
If you go to radiator replacement place It should be free, only takes 5 mins.
kiwi-2,
Apr 19, 2:56pm
Does this firm's last name start with a P (boys name) or do you have a Ford! As rgflav says A radiator shop would have done a test free,A & Lowe .
Apr 19, 3:09pm
i think you want to change your thermostat. the service garage should have told you what i just did as it is common sense when you say it overheated once and not again means the thermostat was hanging shut.
johnf_456,
Apr 19, 4:11pm
Most radiator shops will do it for free, my old work use to as a image thing.
skyline_guy_r34,
Nov 18, 7:42am
Last time I needed it my regular (at the time) mechanic did it for nothing. Only takes the better part of 5 minutes.
