Depends if its good or not. The fact that your add states condition unknown raises alarm and the value drops as the purchase of it becomes a gamble. Also notice the red silicon indicates the casing has been removed. Anyway $350 would be a likely price at the moment. but if you gave it a clean and said its mint you could sell it for $600 easy. and whats the worse that could happen! you have to give the money back if it comes back stuffed, But Its not hard to give it a once over either. inspecting the drained oil and drain bung is a good start, select each gear and spin the input shaft listen for excessive bearing noise and feel for hard spot ie missing teeth.
hijacka,
Nov 13, 1:06am
Personally i would havesold the transfer case separate and removed the gearbox casing and inspected the bearings etc b4 listing it. its not hard,Hey! would you like me to hold your hand fp and walk you through it! haha
