Ok, so I may be a bit dumb, but do you have the steering lock off when towing, and if so, do you have to leave the key turned on!
mrfxit,
Apr 14, 3:16pm
Depends on the A frame If a std A frame then YES, steering unlocked Rigid towing dolly would be unlocked Towing Dolly with a turn table would be steering locked.
(Could be wrong but appears to be right)
woody1946,
Apr 14, 3:25pm
I was sure you would have to unlock the steering ,but was concerned about leaving the key turned on for a long period
morrisman1,
Apr 14, 3:35pm
if the wheels are touching the road = steering unlocked!
morrisman1,
Apr 14, 3:36pm
just take the negative lead of the battery if you are concerned about power.
mrfxit,
Apr 14, 3:45pm
For woody1946
A std conventional "A" frame, is 1 that bolts to the front of a car & ALL FOUR wheels are on the ground . OK!
They are very different to what some ppl call an A frame these days which in fact is a towing dolly. Can you point us at the type you want to use! (photo/ web link etc)
lookoutas,
Apr 14, 3:48pm
The steering shouldn't be locked with the key on Accessory. If the engine goes, and the vehicle has power steering - good idea to leave it running. Have A framed autos with the engine running, and good at night, so the park lights can be left on. I often towed a ute on metal roads, so it was good to leave the AC fans going full blast on Recirculate, which kept the dust out.
petermcg,
Apr 14, 4:11pm
When you are towing your vehical with a conventional A frame. You must have your steering unlocked so the wheels will steer, but you do not have to have the ignition on, it would just be on accsesorie.
barbuzz,
Apr 14, 4:40pm
Hmmm, when I use the A Frame, I leave the steering locked. Always have. I was told to always leave it locked. So towed car works like a trailer of sorts. Hasn't damaged any of my cars. I would think leaving the steering unlocked would cause it to sway! My 3c any way.
lookoutas,
Apr 14, 4:44pm
Far canal! You need a talking to.
petermcg,
Apr 14, 6:27pm
There are different sorts of A frames, the one we are refering to is an A shaped drawbar connected solid to the front of the car getting towed and on to the ball of the tow vehicle, you may have what is called a dolly.
big.b-lil.c,
Apr 15, 6:03am
thats how we towed our old home built offroader years ago, but its steering didnt self center. the first time it went around a corner it was on the other side of the road trying to overtake the tow car. we tired the steering wheel to the rollcage after that
smac,
Apr 15, 6:40am
I think you're either misunderstanding the situation being described, or. well there is no other option. There is NO way a car being towed with a rigid A frame and the steering locked would be manageable without shredding the tyres at the very least.
mrfxit,
Apr 15, 7:25am
Like I said above, some ppl need edumacating
olsod2,
Apr 15, 8:54am
correct me if im wrong when my escudo steering is locked wheels point a wee bit to the left if towed in locked possi tyres would scuff.i have towed this car many 1000s of ks behind my bus always with key on acc.also i make sure i lock the car with my spare key
demons,
Oct 31, 8:48pm
yeah i shredded front son my hq when we towed it with steering locked. was a solid a frame .i see there s ones with telescopic arms now too where one side goes into its self when turning corners.
