Hiya, some more help please, the parts were all installed and timing is done correctly, but apparently the car won't fire over.
phillip.weston,
Mar 26, 4:06pm
does the ECU throw up a check engine light while it's cranking over and not firing!
johnf_456,
Mar 26, 4:09pm
Define fire over, no spark!
raine06,
Mar 26, 4:12pm
From what I've been told it wants to start.
Apparently the spark plugs are fine.
Sorry I do not know anything about cars, I am just posting on behalf :)
raine06,
Mar 26, 4:13pm
I am unsure, I will ask him and if he didn't check, I will get him to :)
raine06,
Mar 26, 4:18pm
Ok, so while he is trying start it up, the check engine light starts flashing.
phillip.weston,
Mar 26, 4:49pm
ok great - that means the ECU has detected something is wrong. Have you got access to an analogue style multimeter, a 12V low-power buzzer or even an LED with an appropriate resistor to work with a 12V source! if so you can then check the trouble codes from the ECU by connecting to the diagnostic socket next to the interior fuse box.
raine06,
Mar 27, 8:58am
Thank you very much for that Philip, he will be going out to purchase what you have mentioned :)
Have a great day! 8]
raine06,
Mar 27, 11:11am
Hiya, SORRY another question :\
When he starts it the A/T TEMP light comes/stays on, will this stop the car from starting.
EDIT: The transmission is fine (or so I am told)
raine06,
Mar 28, 9:08am
Bump 8]
phillip.weston,
Mar 28, 1:20pm
it shouldn't do. I think the A/T temp light comes on when ignition is on and turns off when the engine runs. Kind of like a self check. e-mail me phil <at> philsparts dot co dot nz and I will send you through a PDF on how to check the diagnostic trouble codes. I had the same issue with the '92 Mirage I have listed currently, the crank sensor was faulty and it was throwing error 23 when the code was checked, which quickly allowed me to pinpoint the fault and after a replacement sensor it worked. I'm guessing that the cambelt has been done and the timing gear has been removed, that perhaps the crank sensor (if it has one) on the crankshaft has been damaged.
raine06,
Mar 28, 3:36pm
Hiya Phil, thanks very much for the help!
Message sent, thank you so much for the help! Have an awesome evening :D
raine06,
Mar 29, 4:32pm
Well my partner did the diagnostic and its telling him CKP and CMP failure, how would he go about fixing it, my Uncle will be able to help him when he gets back into town, but if its something Dp can do by himself then he will give it a go :)
phillip.weston,
Mar 29, 6:00pm
if it's the SOHC engine, it should have a distributor which contains the cam sensor, and I think it may still have a seperate sensor on the oil pump housing too. I would check that all the connections are plugged into the distributor, and if that fails try finding another good distributor to swap over to eliminate the distributor possibly being at fault. The distributor houses the position sensor(s) as well as the ignition transistor module, often the module gives trouble but you usually get intermittent running - ie it will start up and run but stop after a few seconds/minutes.
If it's not the distributor, I would definitely check the crank trigger sensor - it is easy to damage - all it takes is the crankshaft pulley not on and tightened up when the crank sprocket rotates and slides along the crankshaft where the trigger wheel can make contact with the sensor damaging it.
raine06,
Sep 8, 9:02pm
Thank you again Philip, I will show Dp your post as I have no idea about cars :)
Have a good night & thanks once again! 8]
