Mitsubishi gsr wastegate?turbo lag
limit11, Mar 25, 11:19am
jus removed my external wastegate off my gsr i recenly purchased
put a blanking plate over the flange cut the tac of the actuator and hooker the vacum lines and went 4 a drive and it feels like a non turbo til about 5000 revs !
phillip.weston, Mar 25, 11:23am
What's a 'GSR'!
Sounds like an exhaust leak somewhere, or boost leak somewhere, or actuator arm is actuating too early! Have you got a boost gauge, if so how much psi does it boost when it does end up boosting!
limit11, Mar 25, 11:27am
mitsubishi gsr like a evo.
it sits on like 2 psi and doesnt move much until high revs and then about 10 psi
ct9a, Mar 25, 12:14pm
4g93t 1.8 turbo
sounds like vacuum issue,incorrectly hooked up
or your internal gate has shat its self
phillip.weston, Mar 25, 12:31pm
OH, you mean a LANCER gsr! You do realise there is a Cordia GSR, Sigma GSR, Galant GSR, Mirage GSR, Starion GSR, Tredia GSR etc right!
limit11, Mar 25, 1:07pm
ohk na i didnt no there were othe gsr models.
fixd the problem the actuator arm was wound to far out thanks.
do u no if the evo tdo5 turbo bolts on or not
ct9a, Mar 25, 1:45pm
they do,require aftermarket downpipe or hits oil filter
phillip.weston, Mar 25, 2:23pm
you'll have to port out the outlet on the exhaust manifold, as on the TD04 Lancer GSR manifold it is offset in relation to the bolts.
ct9a, Aug 23, 8:47pm
ive herd this before yet have fitted 3 no problems.chinese ones of trademe
