Brakes sticking. The brakes on my nissen terrano seems to be sticking in the morning on the first startany ideas what this maybe
coralie,
Mar 23, 9:28am
The brakes on my Nissen Terrano seems to be sticking in the morning on the first start.Any ideas what this maybe!
321mat,
Mar 23, 9:33am
They may be glazed.
Take the pads out, rub them on the concrete,a nd replace. Or, maybe the pistons are sticking. if so, pull them out at the same time, spray them with Brake-Clean, wipe them over, and replace.
dunbar01,
Mar 23, 9:46am
Yeah I'd have to say the piston rubbers may need replacing. Sometimes if you mix the Dot rated brake oil, can sometimes do this. Because some brake oils consist of different compounds.
Mar 23, 10:20am
brakes stick because yo did not service your brakes like they should be and now rust water is seeazing your brake caliper. get prepaired for a big bill to do all front and rear brakes as rust will be everywhere by now.brake fluid need to be flushed out and exchangedevery 18 to 24 month. to prevent the above problems.
johnf_456,
Mar 23, 10:51am
A bit over the top on the situation without know all info about this car.
coralie,
Mar 23, 11:06am
Thanks gives me an idea of what going on.
dave653,
Mar 23, 11:12am
New caliper kits aren't too expensive, if you can do it or know someone handy to do it, it will save hundreds on labour.
elect70,
Aug 16, 4:05am
happened to mecylinder bootsplitrust on edgesso as pads wore stuck on the rusted part . , full O/h of calipersBNT do kitscheap as& gently sand away the rust, it will be past theseal so ok , clean very thoroughly & assemble with copius amount ofbrake fluid .
