91 Toyota Surf auto tranny
mk3zephyr, Jan 31, 6:11pm
has all forward gears, changes gear no worries but hardly any reverse, have to give the old girl a few revs to move (slowly). Clutch pack gone!, 2L-TE, LN-130, Be cheaper to get a 2nd hand tranny or get this one rebuilt!, shame it had to happen at this point in time.
gadgit3, Jan 31, 6:20pm
Could be the trans ecu. Had one do this once. second hand trans ecu fixed it
mk3zephyr, Jan 31, 6:41pm
where is the trans ecu located!, engine ecu down in the passenger side footwell, cheers (will have a google as well), can usually feel it change into reverse like any auto trans will and can still feel it do that but nothing, Fluid is full and nice and red, Filter/fluid etc was replaced about 2 months ago
petermcg, Jan 31, 6:45pm
You should have an A44D trans in your truck, when its clutchs usually its reverse goes first.Overhaul kit would be about $300 from the states.
gadgit3, Jan 31, 6:47pm
Yip passenger kick panel
mk3zephyr, Jan 31, 6:55pm
Okaaaay, had a look on google and there is the engine ecu by the passengers footwell, one under the shifter and one behind the ashtray, hmmmm wonder which one.
Are they pretty straight forward to do!, never done a surf trans before
mk3zephyr, Jan 31, 7:23pm
Trans is an A343F not A44D as peter described
luke041, Jan 31, 7:29pm
It wont be the ecu very common for the clutch to go and peter you can get kits local for $120
mugenb20b, Jan 31, 7:33pm
Yes, but there's a couple more wires to disconnect, flat sump = bonus. You will need a good transmission jack.
mk3zephyr, Jan 31, 7:54pm
yip its a flat sump and yes a good trans jack as they arnt the smallest things are they lol, so who sells the kits for $120!
zooki007, Nov 25, 3:53am
