Auto door locking corolla
sheepey, Feb 9, 2:20pm
Have a early ae101 corolla and it's doors lock themselves at a low speed.I would like to disconnect this feature, can anyone tell me how to do it please!I did same on a early leglessly a few years back with the help of someone on here who gave spot on advice.
cassandra13, Feb 9, 6:00pm
most likely be a fuse or relay, see if you can find one marked in the panel, or under the hood.
bigfatmat1, Feb 9, 7:27pm
find the central lock unit ( will go click when you lock/unlock doors)and cut the purple wire (ideally you need a scope to double check the wire). From memory it is purple.
sheepey, Feb 9, 8:07pm
Thanks for that i will give it a try.
