Help with ticking noise in Suzuki TL1000s motorbi
fatdx, Feb 9, 4:32pm
Has anyone had experience with a ticking noise coming from the motor only when it warms up. Have taken it to be looked at, checked the valve clearances, but noise is still there. Any ideas!
kazbanz, Feb 9, 4:34pm
front or rear cylinder--what year is the bike!
klrider, Feb 9, 5:05pm
you will find the noise dissapears with your helmet on at 100KPH.
fatdx, Feb 9, 5:25pm
both i think does the chain stretch
lookin4ord, Feb 9, 7:53pm
yep sure do, try leaning the bike over while its idling and tell me if it stops if yes side play on the cams
fatdx, Feb 10, 7:15am
If thats the case, is it easily fixed! Or quite expensive!
kazbanz, Feb 10, 7:36am
Yes cam chains do stretch I'm scratching my head that the noise apears to apear only after the bike warms up.
Makes me wonder about the oil viscosity
desmodave, Feb 10, 8:12am
You had better hope its not a gudgeon pin working its way out.Have you done an oil change and had a good look at the used filter and oil for bits of metal that shouldnt be there.
klark, Feb 10, 10:02am
Over time the scissor gear wears on the cams and a "tick" is heard after the cam passes over the lobe, they all do it, sounds just like a tappet. Nothing to worry about. If it annoys you too much you can remove the scissor gear, its held on by a circlip and just preloads the main gear to keep it all quiet but ends up wearing and making more noise ha!
elect70, Feb 10, 1:23pm
shes gonna blow , run
kerrieann, Feb 10, 1:52pm
a little birdie told me that the tl 1000 and the tlr 1000 have whats called an ignition retarder fitted ,apparently it retards the ignition under throttle opening to 15 degrees of retard to stop u wheel standing the beast .ok point is, if the retarder is worn one of the first signs is a ticking noise not unlike a tappet when its hot.also it can be removed for more wheel stands and less ticking.long shot but same symptom
fatdx, Feb 10, 5:14pm
seems the intellegent offer exellent infomation and the the ignorant uneducated post snide remakes will be looking at cams etc
by_hdt, Feb 10, 6:02pm
My father is somewhat of a TL expert, his has done over 130,000km, the hot ticking im told is normal and nothing to worry about, they all do it.
thejazzpianoma, Feb 10, 6:04pm
bjg, Feb 11, 5:52am
I had a tlr 1000 and it always ticked away and had a clunk what you shut it down.
