dam i have a appointment at 12 today and nearly got stuck in our paddock when pulling out of our barn the wheels skidded but only onone wheel i thought these were supposed to be lsd ,luckily i made it to the gravel and can get there ,it only has kuhmo street treadtyres on so i might look at the bf goodrich tyres all terrain tyres i spoke of on the earlier thread
hi-ling,
Feb 15, 9:43am
If you have a look at the body tag, under the bonnet, it will display codes for motor, trans and other options, look for an option code G80. that is for a LSD, if no code then not fitted as standard.
bill-robinson,
Feb 15, 10:36am
of course the type of tyre has no bearing!
desmodave,
Feb 15, 11:18am
Correct the tyre wont have a bearing but the diff will lsd diff is worth having.
geminidragon,
Feb 15, 5:08pm
hi no g80 written under options so no lsd :(
geminidragon,
Feb 15, 5:13pm
hi just got the truck back from having its service and its still got an anoying stumble or slight miss for a second when taking off ,has anyone had this happen to theirs ,they changed the fuel filter as part of the service so its not that,i thought it may have had a little water in the diesel ,blowed if i know
