Brake pad fitting ED
v8_mopar, Feb 19, 10:43am
Back pistons are screw in yes!
How do you get them in. Cheers
brokebloke1, Feb 19, 10:44am
are they a disc brake rear end!
v8_mopar, Feb 19, 10:46am
No shoes on this girl
carmedic, Feb 19, 10:49am
Turn the piston into the caliper while pushing it in (normally but not always clockwise)
Special tools are available but mcgyver won??
v8_mopar, Feb 19, 11:01am
Not having much luck mcgyvering this one. May have to do the job on the bench
nave12, Feb 19, 11:41am
I read this on a forum about doing an ED's rear brakes,if you can understand the way its written it sounds quite simple.
I remove the handbrake lever from the back of the caliper. This exposes two flats on the central screw thingy. Screw it in about 3-4mm with a spanner, then push the piston with a Gclamp much like you do with the fronts. This pushes the flats back out, Repeat the process another 3-4mm. Again use Gclamp. Repeat 3 times and you'll have enough clearance for new pads. Refit handbrake lever and you done. No need for special tool. Works for me, did this just yesterday.
carmedic, Feb 19, 11:42am
What car is it!
Is it turning ok!
v8_mopar, Feb 19, 11:48am
# 7 Was about to go back out so will look at that.
#8 Could not get it to turn. Its a 94 ED XR6 wagon with ABS
v8_mopar, Feb 19, 12:25pm
Thank you! worked great.
