HELP! Ignition light on . wont turn off !
b1anca, Feb 28, 4:54pm
You know the light that glows to show you where to put the key! It wont turn off .
Also the back light in the passengers side wont turn off either .
car is a ford fairmont .
andrea_w, Feb 28, 4:56pm
You have a faulty door switch. probably
b1anca, Feb 28, 4:58pm
Hmmmmm one of the seals is loose on the back door, just went out and slammed it shut to see if that made a diference
Cos it going to make the batt go flat eh!
intrade, Feb 28, 4:58pm
yea if its not off disconnect the minus - therminal overnight.
b1anca, Feb 28, 5:02pm
Oh ok buggerrrrrrrrrrrr
owene, Feb 28, 9:19pm
Have you checked the cantabulator! If you find it in the left position, rotate it to the right and the dash light will go away.
