if you mean tri-matic, yes some are chev bolt pattern
gmphil,
Mar 4, 12:27pm
3 on the tree v8 boxes as in the ht . I believe there were trimatic pattern so ul need chev bellhousing
brokebloke1,
Mar 4, 1:08pm
sure your not talking about the old powerglide they had them in hk,hgs the 307 chev motors were bolted to these I had a 400sb chev bolted to a old powerglide was great at the drags only two gears
lordv81,
Mar 4, 4:12pm
No trimatics were chev pattern. The easiest way to bolt up a manual GMH 3 speed to a chev is use the GMH chev bellhousing off a 4 speed box.You will have to use the chev flywheel and put the holden clutch on it for the right spline match,as well as a spigot bearing/bush match,you will have to check input shaft length.If you use a 6 cyl box you will have to machine the bellhousing face as they have shorter input shafts than the v8 boxes{you can swap the v8 and 6 shafts in most boxes} If you want to use the 3 speed trimatic then you will have to use a redrilled flexi plate and modified bellhousing.But then why would you want a trimatic !Im guessing you are wanting a manual!
demons,
Mar 4, 4:18pm
yeah mate want it manual,,,, using a 3 speed box. i can sort out mecanics of it but yeah the old 3.3 aint doing it for me but want to keep it on the tree
neville48,
Mar 4, 4:29pm
try and source a New Zealand new 3 spd chevy box and put the whole deal into the holden or a yankee one but use the crossover system down on the box and use the column shift. If yur lucky you may get a 3 spd and overdrive chev column box, that would be real cool in a holden.
roadkillcafe,
Mar 4, 4:33pm
ive been told 308 goes straight up to 3 on tree manual in hq
demons,
Mar 4, 4:49pm
yeah heard the same.
demons,
Mar 4, 4:52pm
thanks for the info.308 would be cool on the 3 speed wonderinghow long it would last. the 283 ive got is old so not overall powerful.
roadkillcafe,
Mar 4, 4:54pm
whats it in!
demons,
Mar 4, 4:58pm
i have a wb ute
roadkillcafe,
Mar 4, 5:15pm
is it manual!i once measured up the possibility of putting a slant six into my mate's manual hq ute (cos slant sixes are awesome and the 202 would barely get out of it's own way-and use pretty much as much gas to boot.) but the wiper motor was gonna be in the way :-(then he was told its pretty easy to put a holden v8 into it. never got around to it tho and in the meantime i think it just gets used for short trips where no hills are expected lol.
demons,
Mar 4, 5:43pm
yep its manual .motor has been rebuilt but yeah gutless.dumped exhaust at diff made small differance but then put 20s on it which stuffed that up
gmphil,
Mar 4, 6:55pm
308 motor came in two bellhousing patterns.early one is trimatic and same as 253 and later version is chev pattern know as turbo pattern
