ignition in my odyssey is acting up and causes car to stall. I know there's a recall for it in USA but not sure if NZ models are part of recall. Is this something local dealers can fix for free or should i just DIY it!
jasongroves,
Mar 30, 11:26am
I would ring your local Honda agent and ask. Best from the horses mouth in cases like this. Without knowing the specific fault, then its very hard to say whether you should or could DIY it. Ring Honda first, then go from there is my advice.
saki,
Mar 30, 3:03pm
After 13 years
rick07,
Mar 30, 7:07pm
Real common fault. Replace the electrics on the back of the ignition switch and you will be sorted
