Nissan z16 engine
sheepey, Mar 30, 2:07pm
Can anyone tell me the correct timing, spark plug type and gap and points gap for the above motor in a carbed d21 navara please!I am unable to find anything on the net!Cheers.
andy61, Mar 30, 3:53pm
Im sure you have looked,but sometimes the timing settings are on a sticker on the underside of the bonnet, are you sure it has points!
jasongroves, Mar 30, 4:27pm
Closest I can find on Autodata is J16 or Z20.
jasongroves, Mar 30, 4:33pm
NGK plug :BP5ES-11
Its pre-gapped to the correct 1.1mm.
sheepey, Mar 30, 5:19pm
Cheers Jason, has those was concerned they might have been a bit hot.Anything on timing or points gap!
jasongroves, Mar 30, 5:39pm
Nope. Very little info on the Z16 sorry.
Might be worth trying the local library or Nissan workshop for the info.
Also try here: http://pdftown.com/ Nissan clubs/forums on the net might be worth a look too. If you find a Navara/Pathfinder specific one they may be able to help. Early Bluebirds used the engine too so may be worth a look. http://nissanbluebird.8.forumer.com/
sheepey, Mar 30, 5:52pm
Thanks again, been down those path's already with no luck, that is excluding the visit to the library.Cheers.
xs1100, Mar 30, 5:57pm
z24 gap.20 points would be surprised if you are using plugs gapped at 1.1 on a carb mtr
pettal, Mar 30, 6:14pm
if it's any helpthe NA16engine was the "Z" series replacment .
jasongroves, Mar 30, 6:26pm
Good point actually. I think I copied and pasted the plug number for a Bluebird with the Z16E.
BP5ES with a gap of 0.9mm sounds more accurate.
skin1235, Mar 30, 6:53pm
try for the j16, '86nissan pickup ( datsun 720 ), these became the Z series motors in the later models and I think you will find the Z16 is a rebadged J16
jason, are you using AD3, or have a you a later version
xs1100, Mar 30, 7:07pm
would go for .08 on plugs which is standard gappingand at worst use a hacksaw blade.if looking up a haynes or gregory manual look for the AIRGAP thats how they describe it and as i say i set mine at .20 on a z24 carb motor so should be the same
jasongroves, Mar 30, 7:10pm
I have version 3.18 and version 3.24
