I dont know, but my power steering is cutting out and is hard to turn some corners, its also making the steering wheel creak when I turn but then it goes back to normal! does anyone know what this means!
tonyrockyhorror,
Mar 30, 6:48pm
Low on power steering fluid which is the same as automatic transmission fluid and also needs to be checked with the engine running. In which case you need to investigate where it has gone.
jmma,
Mar 30, 6:50pm
1957 Vauxhall's didn't have power steering (o:
edkemper,
Mar 30, 6:56pm
Thanks will have a look at that!
unbeatabull,
Mar 30, 7:01pm
Thinking they were hinting that it would help us if you told us what your car was that is having the problems
edkemper,
Mar 30, 7:08pm
its a 95 fairmont
jmma,
Mar 30, 7:11pm
Have you checked for a loose belt!
hamishcookie,
Mar 30, 7:18pm
Careful not to over fill it if you top it up or it likes to go all over your alternator.
unbeatabull,
Mar 30, 7:25pm
Check drivebelt, P/S Fluid level, otherwise your looking at a new steering rack - fairly common on that model
tonyrockyhorror,
Mar 30, 10:40pm
In that case start by looking at the pressure switch on the steering rack (drivers side) for a leak. They're notorious for it. It's the exact same one as the one on the brake master cylinder that kills the cruise control.
panicky,
Mar 31, 6:18am
The pumps also leak as people put normal dx3 type trans fluid in when they're supposed to have type F trans fluid/power steering fluid.
