ive got a 99 tsr the ej20 quad cam engine, just replaced air flow meter as idling is never the same, and is very slugglish, and uses lots of fuel any ideas on what it could be!. thanks
thunderbolt,
Apr 17, 7:18pm
Cam timing correct!
vandewc,
Apr 17, 7:21pm
Its subaru :)
cp2011,
Apr 17, 7:23pm
wrong afm or faultymaybe 02 sensor
n1smo_gtir,
Apr 17, 7:44pm
spark plugs fouling! Oxygen sensor packing the sad. was replacement airflowmeter 2nd hand! if so, pays to have a look at those fine sensor wires to see if they are dirty or not.
steph1211,
Apr 17, 7:56pm
cambelt just being done so will be, havent checked plugs airflow was a 2nd hand unit might be dodgey, wat is 02 sensor!
bubbles244,
Apr 17, 7:58pm
yes subaru's are always an issue
motorboy2011,
Apr 17, 8:03pm
BEING done or has just BEEN done!
n1smo_gtir,
Apr 17, 8:12pm
O2 is oxygen sensor. faulty o2 sensor generally contribute to alot of excessive fuel usage other than a heavy right foot or poor selection use of gears.
steph1211,
Apr 18, 2:03pm
cam belt done like 200km ago $1000 later. ok will look into that thanks
mecanix,
Apr 18, 2:13pm
Cam timing.
steph1211,
Apr 18, 3:45pm
how can it be cam timing! it was doing it before cambelt was done and belt was on marks etc
mecanix,
Apr 18, 5:20pm
ok. thats not clear in your posts.
hijacka,
Apr 18, 5:51pm
You could either ask for more guesses here in the hope someone is gazing into a crystal ball at the time for a more accurate physic reading or you can check the fault codes. if nothing could be fuel pump At a guess.
steph1211,
Apr 20, 2:24pm
how can i check the fault codes
