for draining water Pulsar '92, 1.6L manual, three doorWas so tight it's philip(sic) head now smooth. Which means disconnect bottom hose to drain! And, revs at about 1000! Just acquire car today, don't know it's history. Thank you.
Apr 19, 7:08pm
Yes, remove bottom hose to drain.but.no, don't rev it.in fact, make sure the engine's off!
ottoitis,
Apr 19, 7:12pm
I'm sure I'll remember engine is off.
jmma,
Apr 19, 7:14pm
Are you trying to say that it idles at 1000 rpm!
Apr 19, 7:16pm
So why do you want to rev it at 1000rpm!
ottoitis,
Apr 19, 8:37pm
Just bought car today from here.
realtrader1,
Apr 19, 8:40pm
Sorry, might seem like a crazy question but, why do you want to drain the water!
jmma,
Apr 19, 8:43pm
Getting blood from a stone would be easier (o:
ottoitis,
Apr 19, 8:46pm
Water very rusty colour, .
ottoitis,
Apr 19, 8:49pm
Yes, it idles at 1000 revs. I will have a go tomorrow how to adjust it.
ottoitis,
Apr 19, 8:57pm
That's the one.
realtrader1,
Apr 20, 1:40pm
Well, you've got issues there.Sounds like it hasn't had corrosion inhibitor/antifreeze in the system for a while.Radiator could be clogged.I would check that.While you're at it, check thermostat and rad. cap.Will need to use a good flush additive in it.Follow directions on the pack.Then correct quantity of inhib, antifreeze and water.
tonyrockyhorror,
Apr 20, 2:59pm
And you still bought it! What a mug.
Apr 20, 4:03pm
well it was omnly 1200$ and has rego on it so it would have been worth it provided its not stuffed. but change radiator waterpump thermostat and all hoses that are stuffed. you can squash hoses if they sound like potato chips are inside it then they need to be replaced soon.
