little oil in the water so the gaskets prob not healthy, plan is drive it till it dies. how hard is the head gasket to do! have a cam belt or chain! cheers
opos,
Apr 19, 11:23am
don't they have pushrods
motorboy2011,
Apr 19, 11:25am
thats also what I did wonder.would make a head gasket job easier
1ollie,
Apr 19, 11:41am
Drive it untill it dies is just stupid as then you are allmost gaurented to wreck more stuff like warp the head etc! fix it now and save yourself some money and effort
kingfisher21,
Apr 19, 11:50am
Be cheaper to buy another whole engine rather than redo the current one, good runner can be had for as little as $300.
elect70,
Apr 19, 12:14pm
Head setsare cheap asAClV8Rovercomptete with themanifoldoil /galllerygasket$180. so v6 cheaper stillDont trust second hand motorsDo it in an 1/2 day
kingfisher21,
Apr 19, 12:26pm
Gasket set cheap yes, but if the heads are warped, cracked etc you'll be up for a lot more than a 2nd hand motor, heads should really at least be surfaced before they go back on so add that cost as well.
motorboy2011,
Apr 19, 4:00pm
so its a push rod motor or what! how hard to do the gasket myself!
kingfisher21,
Apr 19, 4:08pm
Pushrod, dead easy to do, the worst thing is probably the intake manifold and associated bits.
motorboy2011,
Apr 19, 4:11pm
cheers. its the inlaws 2nd car so will inform them
msigg,
Apr 19, 4:15pm
Pushrod, I think you need to change your user name.
a.woodrow,
Apr 19, 4:17pm
That's a bit mean. He's claiming motorboy, not motorman.
realtrader1,
Apr 19, 5:34pm
Let's keep coming back to first principles.A little oil in the water could mean anything.It could even mean that someone inadvertently tipped a little in!If it's an auto, could be getting in that way.Someone may have put in a cheap additive in the radiator too.Need to do some tests to ascertain if there is actual leakage before determining what to do but driving it into the ground.Well if it was a lower milage unit eg, that wouldn't be my suggestion even if there were actual issues.
treachug,
Apr 19, 6:18pm
When you start doing the head gaskets, stop once the inlet manifolds have been removed & have a good look at the inlet gaskets & inspect them for leaking/blown gaskets - mind you wont be hard to miss. 9 times out of ten it will be that & not head gaskets - V6 commodores are reknowned for it. Easy fix & repair.the gaskets blow out around the inlet ports at the ends leaking oil into water or vice versa.
phillip.weston,
Apr 19, 8:46pm
^^ what this man said!
elect70,
Apr 20, 12:38pm
i justput atraight edge acrossdiagonaly& see if can getfeeler blade under. only skim ifneeds it , these days of thin wall castings, if its been cookedneedhardness testtoo
kingfisher21,
Apr 20, 12:59pm
On a Commodore V6 this will NOT cause oil in the water, water in the oil yes, but not oil in the water.
kingfisher21,
Apr 20, 12:59pm
On a Commodore V6 this will NOT cause oil in the water, water in the oil yes, but not oil in the water. Is it an auto! Trans cooler in the radiator would be another suspect to look at.
motorboy2011,
Apr 20, 4:39pm
yes its auto
bubbles244,
Apr 20, 4:43pm
replace the radiator first
motorboy2011,
Apr 20, 4:44pm
what about an external trans oil cooler!
realtrader1,
Apr 20, 7:02pm
Bars Leaks product can give an oily look.you probably need someone to look at it and do some checks.
motorboy2011,
Apr 20, 7:27pm
thats my job, hence asking here.fix it, sell it or swap it!
