Ford AU2 6cyl Oil Sump leak
yeahm8, Apr 25, 6:28pm
Hi, my AU2 6cyl has developed an oil leak coming from the sump gasket, it looks pretty tight under there so are asking if it's an easy job.what needs to be done to replace the gasket!
robbo36, Apr 25, 6:31pm
To change the sump gasket, you will need to drop the front end.
yeahm8, Apr 25, 6:59pm
A big job!
unbeatabull, Apr 25, 7:00pm
Are you sure its the sump and not the front timing cover! Very coming for the covers to leak and then the oil runs down and around the sump.
yeahm8, Apr 25, 7:49pm
Yep it's coming from the rear of the sump, deceased around sump and it came through.cars done 497k.
unbeatabull, Apr 25, 8:08pm
Rear of the sump! Checked rear main seal and rocker cover/head gasket!
I gotta say, I've only ever seen one AU sump actually leak (other then ones that have been off and not resealed correctly etc). Seen a lot misdiagnosed though
