where the bl@@dy 'ell do you buy them in jafaland!
fordcrzy,
Apr 13, 9:09pm
upgrade to LEDs
scoobeey,
Apr 13, 9:20pm
skin1235,
Apr 13, 9:22pm
try bike shops ( common as headlights in quads) supercheap ( common in small spotlights )
why 35w, 21w indicator bulbs will work well enough
hijacka,
Apr 13, 10:21pm
LEDs are shit! A Caravan in jafaland should have HPS ;)
Apr 14, 5:02am
leds is the best you can buy today for light . normal light bulb are no longer sold in europe same will be here soon also
cuda.340,
Apr 14, 6:41am
35w aint that bright so 21w will be even dimmer. it's obvious that most of the replyees dont understand the size & shape of the bayonett fitting that goes into a caravan light. car bulbs just do not cut it, they're a special breed of bulb. LED's are not an option either since they glow in one direction & the caravan needs 360* glowing space.
Apr 14, 6:43am
change the friggen fitting that holds the bulb then how hard can that be.
skin1235,
Apr 14, 6:50am
so where have you tried assume repco, the local auto sparky, every caravan sales yard, every camping store, van restoration etc have come up empty
Apr 14, 7:24am
Hi Cuda. Direct answer is to go to a chandler (boat supplies) But also -someone else suggested it but I'll repeat it for ya. I'd stongly recommend you upgrade the fitting to LED'sTheres a couple of reasons. First being that LED's don't generate heat like a normal bulb does and secondfor a lot morelight an led"bulb" draws a heck of a lot less power from your batteries than a normal bulb. You will honestly be totally blown away by the improvement. I think the boat show isn't far off if you want to see how effective led's are at lighting a "room" I'm not talking "google advice" here mate. I just redid mum and dads Hiace campervan with LED's because dad kept flattening his (big) battery when they parked it up for a few days.
cuda.340,
Apr 14, 7:26am
i've tried, Repco, Appco, Partsmaster, Supercheap, Jayco, JA Russell, Ideal Electrical, Hella,Lighting Plus & a handful of Auto sparkies but that link you posted Intrade maybe the one.
cuda.340,
Apr 14, 7:54am
i'm not worried about sucking up battery power as the caravan is hooked up to 230v all the time, it just has a transformer that drops the lighting curcuit down to 12v on a 2 core wiring curcuit. the thing is the caravan is a 1962 retro unit & all the lights & fittings are the neat old stuff.
Apr 14, 7:57am
ok cudawell try my first suggestion then -a boat chandler. the guys that supply bits for all the pleasure boaties. I know its a bit outa your way but theres a heap of em in and around westhaven
snoopy221,
Apr 14, 4:37pm
Hope Hickman union st city.
bigfatmat1,
Apr 14, 6:18pm
skin is correct in saying you can buy a 35w for a mb with same base as a 21w indicator bulb you can also buy holagens with that base ba15shere is a 45w version any auto electrician can get http://www.hella.co.nz/3-346-992/product/Special-Bulb---12-Volt
LEDS generate heat, the new Philips 10W MR16 lamp actually has a fan built into the rear of it. Other LEDS have massive heat sink to disipate heat. Im not sure where this LEDS dont generate heat myth comes from. Either the LED or the driving gear for the LED make heat, and obviously the higher wattage the more heat.
