I have a squeeling noise under the bonnet which is worse when the car is cold and stops when I turn the A/C off. I'm a complete novice at all things car - but it was serviced less than 6 months ago - so I'm figuring it can't be too bad. I think it must be some sort of belt.Does that sound right!If so - does it need replacing, or just some kind of lubrication! I will take it to the mechanic if necessary - but it's such a pain to have to work it in my schedule!Would be great if there is something I can sort out in the weekends. The car is a Nissan Pulsar 2000 if that makes any difference. Thanks for any advice.
xs1100,
May 5, 7:50pm
get a can of crc tac too from repco tommorrowand spray it on your belts and also use on your door hinges and locks all good
a.woodrow,
May 5, 7:54pm
Just get the belts checked and adjusted. Spraying crc etc on them softens them and shortens their life
aunty_jj,
May 5, 7:55pm
Thanks - I was hoping some quick fix like that might be the answer.I will definitely get onto it tomorrow - the noise is so embarrassing!
gastirling,
May 5, 8:14pm
I second that.
hijacka,
May 5, 8:17pm
It would be! I hear people like you drive past and it makes me Cringe.
tonyrockyhorror,
May 5, 10:02pm
They squeal because they're worn, perished or mis-tensioned - or a combination thereof. Replacing them is the only permanent and proper fix. It'll cost you more to have that done later if you use a product like "Belt Grip" because that goo then needs to be removed.
May 6, 8:05am
I second getting the belt tightened as first port of call. Buying belt grip for a one off belt issue is silly. Better off buying a new belt and having it fitted.
len_f,
May 21, 10:23pm
hi mind your hands try old method blackboard chalkmake sure it gets into the grooves if you have a ribbed belt
doug207,
May 21, 10:54pm
Get the belt checked/tightened and technically it doesn't have a fan belt (just being pedantic)
