Can any indicate how much to do a cambelt on a 2.2l diesel 3C-TE engine.
beast9,
May 6, 7:45pm
last one i done there was around $200 in parts and 8 hours to do it
May 6, 8:24pm
$1000 or so to replace the cambelt, tensioner, water pump, etc. Not a nice job.
alan1111,
May 7, 4:44am
I cringe when these come into the workshop and ask how much to do a c/belt. $850 +parts aint bad in price its the labour that is high as a mongrel to do i hate them.
gadgit3,
May 7, 5:14am
There getting a bit of age to them now so I would have the injector pump pulled and a new seal kit fitted also while your in there. Bout $1300 with cambelt, idlers, water pump, seals and the pump seals done. Thats if you can find a workshop that can do the injector pump in house. other wise you'll be looking at $900 just for the pump seals.
May 11, 5:28pm
dont even bother to change the cambelt drive the pile of crap till it stops just change oil and filters. They all crack heads soon after you do a cambelt change so save your money . you can do it when the head has gone or scrap it .when it went pufff
r15,
May 11, 5:59pm
or just dont overheat it.and it'll never crack
May 11, 6:08pm
how are you going to do that when the temprature gagua never shows hot! they just start blowing white smoke water vapur out the exhaust and then you know its cracked the head no other symptoms on these . the cooling system is like a pot of spaghetti it can let air in at any joint when it gets older. The one i fixed had a coolant leak right next to the headnever showed any temp rise just the famous white smoke out its tail.
gizmsme,
May 11, 6:27pm
Maybe just maintain the cooling system with regular radiator cleans and new antifreeze, just like oil changes only not as regular.Simple really!
zephyrheaven,
May 11, 6:44pm
This is the 1st one Ive heard of still running tbh
r15,
May 12, 6:41am
yeah, pretty much.and just like oil changes, if you dont do anything it will eventually shit itself.
with the knowledge you have about toyota's slow to respond temp gauges,you could simply fit a cheap after market gauge for piece of mind.then you too intrade could have the same excellent experience with toyota diesels that thousands of others rave about
