Hi I have a Nissan Caravan E24 with a td27 turbo. When I start it first thing in the morning it smokes a little, (blue smoke). But if I drive it say to the shop and turn it off, when I start it again smokes blue, but really bad like smokes the street out and you cant see behind you. Then once it warms up its fine no smoke at all drives normal. Any ideas! Apparently the previous just put a recond turbo in it.
mm12345,
May 15, 12:01pm
Blue smoke is oil.It probably is the turbo.
bubbles244,
May 15, 8:24pm
yep.bout 480ish for turbo rebuild if you take it off your self and put it back on yourself after the rebuild
ralphdog1,
May 15, 9:06pm
Quitline!
